Sheet metal 45 degrees flange
hobie_smith
hobie_smith Member Posts: 35 ✭✭
If you attach a flange of 20mm length, measured from the radius to the outer edge, at a 45 degree angle (pointed) to a sheet metal model. How are you doing? I would like that this flange has 20mm, if I measure it it is always much shorter. Will link to an example.
https://cad.onshape.com/documents/4fb52b1f1060526730fa9864/w/1b4ef834c4083f079a0d5de5/e/3233f7b4df0cb79676760376
