Need help creating a particular geometry
FDF_Drafting_Dept
FDF_Drafting_Dept Posts: 5 PRO
edited July 2018 in Community Support
Hi, I needed a hand creating a sheet metal part. It is going to have three faces welded together, but I can't get the initial geometry correct. Essentially, I need a rectange with a chamfer that follows a curve and tapers towards the top on the corner. The top depth is less than the bottom. I believe I need the loft feature to complete the shape, but I'm not sure. Any suggestions would be much appreciated.
  • FDF_Drafting_Dept
    Actually, by playing with it a little, emagdalenaC2C did figure it out. Thank you for the help. I just had to enlarge the circle for the extrude remove and use the coincident constraint on the corners.
