Sheet Metal options?
don_williams909
Member Posts: 139 PRO
I need to be able to create a flat part, make some cuts either by laser of punch, roll it, then add an emboss feature after it is rolled.
Does Onshape have this ability? I can find where I can create a rolled part from a sketch, but I can't convert a solid into a rolled sheet metal part.
In the image below, I have a flat part, that I want to roll into the shape in the background. The of course comes the emboss feature...
Thoughts?
Thoughts?
1
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646@don_williams909
You should be able to click the "sketch" tool in the toolbar, and then select a face of the flat pattern (in the sheet metal flyout) as your sketch plane:
https://cad.onshape.com/documents/3bfe678e50db9ed3bc2f981f/w/33a760ac0a2786f6beb3e439/e/3a5d353f13151c3ef8f9cab4
Jake Rosenfeld - Modeling Team6
And here's an example.
In SolidWorks, I used to have a form tool library with all my available stripit tools, when I wanted to add to a sheet metal part you just opened the flyout and dragged them onto the part, very simple and worked with ease once you had the library settings correct. The only issue with SolidWorks was the flat pattern always retained the emboss and dxf had to be edited to remove the tangent edges from the retained enbose before sending the programer.
Onshape's solution of adding the sketch to the flat pattern as @Jake_Rosenfeld showed works without post dxf editing but ideally, we need the enboses to be parametrically linked and showing up as formed features on the 3d view. Having to add a finish sheet metal feature then position unlinked enbosses is not acceptable in my view. We also need a way to build out an punch/enbose tool library.
