Assembly not Updating with Parts Studio Changes
timtim
timtim Member Posts: 4 EDU
I'm still early in the learning process of Onshape and can't seem to figure out why my Assebmly has stopped updating with my Parts Studio changes.
Here is a copy of the document: https://cad.onshape.com/documents/02b6b3c2259e290ef3b61e45/w/f1d90e03301051f3713902c0/e/4515d4c554fb82bca8410db9
  • timtim
    Accepted Answer
    I think I may have figured it out. When changing the Long Tube's configuration (using a configuration variable) I need to select all the parts impacted by the change of the variable. By doing this it seems to work; at least a few different options I've tried so far have worked.
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,099 image
    Accepted Answer
    Yes, once a part has been assembled as a configuration it must be swapped out if you want to use a different one. Configurations variables create a unique instance every time you change a value. Are you sure you need configurations for your design? Would just regular variables be better (that way updating parts will update the assembly)?
  • NeilCooke
    If by “not updating” you mean that when you create new parts they don’t appear in the assembly, that is correct. A part studio is not a subassembly it is just a collection of related parts that can be used in different assemblies. Any new parts must be manually assembled into the assembly.
    BTW your doc is shared as a link not public so nobody can copy it to investigate.
  • timtim
    Neil, thanks for the response. I don't think I did a good job of explaining the actual problem.
    I did not add any new parts in the Part Studio that are not appearing in the assembly. The "updating" I'm referring to is the parts are not updating (e.g. length of parts, extrude/removes are out of place, etc.).
    Sorry about the link, this one should be better: https://cad.onshape.com/documents/02b6b3c2259e290ef3b61e45/w/f1d90e03301051f3713902c0/e/4515d4c554fb82bca8410db9
    I'm still learning all the ins and outs.
    Thanks!
  • timtim
    Accepted Answer
  • NeilCooke
    Accepted Answer
  • timtim
    You are correct, I can simply do it with a variable. Not sure why I was trying to make it harder than I needed to.
    Either way, I learned more about Onshape in the process.
    Thanks for the help! I'll mark this as answered.
