Assembly not Updating with Parts Studio Changes
timtim
Member Posts: 4 EDU
I'm still early in the learning process of Onshape and can't seem to figure out why my Assebmly has stopped updating with my Parts Studio changes.
Here is a copy of the document: https://cad.onshape.com/documents/02b6b3c2259e290ef3b61e45/w/f1d90e03301051f3713902c0/e/4515d4c554fb82bca8410db9
timtim
Member Posts: 4 EDU
I think I may have figured it out. When changing the Long Tube's configuration (using a configuration variable) I need to select all the parts impacted by the change of the variable. By doing this it seems to work; at least a few different options I've tried so far have worked.
NeilCooke
Moderator, Onshape Employees Posts: 5,987
Yes, once a part has been assembled as a configuration it must be swapped out if you want to use a different one. Configurations variables create a unique instance every time you change a value. Are you sure you need configurations for your design? Would just regular variables be better (that way updating parts will update the assembly)?Senior Director, Technical Services, EMEA1
BTW your doc is shared as a link not public so nobody can copy it to investigate.
I did not add any new parts in the Part Studio that are not appearing in the assembly. The "updating" I'm referring to is the parts are not updating (e.g. length of parts, extrude/removes are out of place, etc.).
Sorry about the link, this one should be better: https://cad.onshape.com/documents/02b6b3c2259e290ef3b61e45/w/f1d90e03301051f3713902c0/e/4515d4c554fb82bca8410db9
I'm still learning all the ins and outs.
Thanks!
Either way, I learned more about Onshape in the process.
Thanks for the help! I'll mark this as answered.
