Cant Awaken for Dimension or Convert Faces on Cylindrical sides?
So when I try to make a sketch and use a cylindrical face's top or bottom relative to sketch plane to dimension off of I cant awaken it as a line nor can I use convert entities to make it into a line. This is killing my design intent as I have to dimension off of weird points I put on a while back into my design.
Am I doing something weird, or is this not a feature? Is there a work around or a better way to do this?
Thanks.
Thanks.
andrew_troup Member, Mentor Posts: 1,585 ✭✭✭✭✭
That's a capability referred to in other packages as a 'silhouette edge' relation. Not yet something OnS can do. It is certainly a handy thing to have.
In your situation, I would create a sketch on the midplane of your solid which lies parallel to your viewing plane "when normal". I would draw a line near to the desired location, then create "pierce" relations between each endpoint of that line and each of the circular edges of your solid.
This would lie along the required silhouette5
TVP, Onshape R&D
(I'm actually wondering whether, in cases where, say, Solidworks would routinely report "Unable to identify edge for silhouette", OnS might be able to seek some user input, and thereby provide a quicker, easier way to achieve the desired result - I'll think about that some more before raising a ticket)
TVP, Onshape R&D
OS needs to implement a tool to create a curve of the intersection of a face and the sketch plane.
