Sweeps not ending flat on the top plane
paul_bartlett
Posts: 98 ✭✭
I have created everything from the top plane. but when I do the sweeps, top and bottom, they do not join properly. Its like the ends of the sweeps are not flat.
can anyone see why this is happening?
https://cad.onshape.com/documents/06fd8f454cc9421496898dab/w/3d59712bc712b104a2638483/e/8237c5a7f5ea235618bbd193
If you want to sweep along a perfectly circular path, you can replace your sweeps with revolves, as I've done here:
https://cad.onshape.com/documents/8e2a718c4550b07f7ff0bcee/w/cbcf9c797b94a4e7c60bcbb3/e/619cb156672f49defcd50b3b
You can even use your arcs as revolve axes, so this was a particularly easy conversion!5
You can even use your arcs as revolve axes, so this was a particularly easy conversion!5 -
Thanks I didn't know about using the arc for a revolve axis. I like it0
