Importing files.
chand_basha
chand_basha Member Posts: 66 EDU
Hi,
     I have been trying to import some data(.step) into On shape. But it showing errors like "Invalid or corrupt input file" and "Your import of DS20 00 00.STEP does not match any import history from the current window. I have tried out both the ways of importing. Please let me know how to import this properly.
  • 3dcad
    3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    You shouldn't have to do anything else than Import -> Select file -> Select import options -> Done. Step file appears to one tab and converted model creates needed tabs.
    Maybe there's some problem with the step file? Have you tried any other files?
  • Hakro
    Hakro Member Posts: 67 ✭✭✭
    Did you try to open your STEP file with a free STEP viewer?
    Programs I use to view STEP format:
    - eDrawings Viewer (www.edrawingsviewer.com)
    - Solid Edge Free2D+Viewer (www.plm.automation.siemens.com)
      https://community.plm.automation.siemens.com/t5/Solid-Edge-Blog/Solid-Edge-2D-Drafting-now-views-3D-files/ba-p/430549
    - STP Viewer (www.stpviewer.com)
  • chand_basha
    Hi, 3dcad
                     I have imported step files previously with out any issue. But now I am facing problem, And Unfortunately I have my required file in STEP format only.
    Will file size makes difference in importing ?
  • owen_sparks
    owen_sparks Member, Developers Posts: 2,660 PRO
    We need to know if it's an Onshape problem or a problem with the step file, this is why @hakro has asked you to open it in other applications, if they all show it's bad then the problem is not with Onshape, if they open it just fine then you can raise a support ticket for OS to find the problem...
    Owen S
  • philip_thomas
    philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381 image
    @chand_basha - That error message is typically only displayed if you 'refresh' the browser tab while the translation is still in progress.
    Nothing bad has happened and the translation will continue.
    One of the many benefits of Onshape is that an action (such as importing), does not tie up your machine resources, you simply carry on working.
    A request to import/export is spun off as a separate (asynchronous) task. The state of the task can be seen in the 'notifications' drop down (the bell).
    When the translation has finished, you will either see the parts/assemblies appear as new elements, or an error log in the same window.
    and when completed . . .
    Philip Thomas - Onshape
