Assembly mate
timo_8
Member Posts: 4 ✭
Mating things seems really wierd and I find it quite counter intuitive.
How can I easilly mate 2 faces to each other so that it doesnt snap to any point?
What I'm trying to do is to mate the "bottom" face of the extrusion to the baseplate and get the extrusion flush with the shortedge.
https://cad.onshape.com/documents/53a139fbec5543c2ba268e34/w/edb4f698353e4908930e4c66
david_sohlstrom Member, Mentor Posts: 159 ✭✭✭@Timo Here is a copy of your assembly with one leg constrained. Take a look and you will see how I did it.
https://cad.onshape.com/documents/6767d7910e1342c2a671d97e/w/636d1fae8c344517918d3d0c/e/5d7b24c9c14945478b7bb7f5
DaveDavid Sohlstrom
Ariel, WA5 -
cyclonewade OS Professional, Mentor, Developers Posts: 53 ✭✭✭Hi Timo,
I ended up adding a mate connector in the 30x60 strut member located by a midpoint sketch element.
I'm sure others have different ideas.
Good luck.
imagine.create.deliver5
I unable to preview your model with the link provided above. How about a new link or some screen shots. The document needs to be public for anyone in the forum to look at it with a link. I too had hard to time with the higher level mates at first, but now I'm a convert.
W.
Dave
Ariel, WA
Good luck.
So basically there is no "easy" way to do it.
Maybe in the future we'll see other mate methods..
Best regards,
TT
Once you get a handle on it you'll say duh.
Dave
Ariel, WA
Now that would be a good addition to the snap mates if onshape could detect that point automatically, the basic shape of that extrusion is rectangular after all! So 4 corner points and 4 midpoints..
Adding mate connectors in place during part modeling forces you to think ahead and be a little bit smarter from the beginning.
