Parts color in assembly
fma
Member Posts: 87 ✭✭
Hello,
Is there a way to override the default color of a Part in an Assembly?
Thanks.
Thanks.
2
Not at present, but it's a much asked for feature. You could possibly set up a configuration of a part (with the color configured to suit) and insert that in the mean time.if that helps?O.S.Business Systems and Configuration Controller
HWM-Water Ltd6
HWM-Water Ltd6 -
Good idea, the configuration! That's a good workaround. Thanks!0
Sure thing, Owen SBusiness Systems and Configuration Controller
HWM-Water Ltd0 -
But I can't change the configuration of sub-assemblies parts
I guess this would require configuration feature in assemblies... 1 -
Yes we are all very much looking for to Configs for assemblies.fma said:But I can't change the configuration of sub-assemblies parts
@owen_sparks Can we control the transparency with configurations? that would be a good option if not.0 -
brucebartlett said:@owen_sparks Can we control the transparency with configurations? that would be a good option if not.Hi Bruce. Indeed we can.
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0
