Trouble converting to sheet metal part
callum_ellis
Member Posts: 11 EDU
Hi everyone,
I am having trouble adding a flange to a piece of a model I have built. I had made a previous version and added the flanges without any issues but for some reason I seem to be missing something vital here. Could someone assist me in understanding my error?
Callum
https://cad.onshape.com/documents/f06185a7708bb5be44432a07/w/2ea70e32f1b7fe2d4c39ee13/e/86ffc1a50393f6022131b173
Callum
You can only use sheet-metal tools on an active sheet-metal part.
Extrude is just a normal part.
So delete the extrude and use the thicken option in the sheet-metal model command.
Then you can add your flanges
https://cad.onshape.com/documents/a39db7615a2a945ffb7076c3/v/85b54ce58d43d22a3d6c02ce
