Fix PCB Custom Feature
owen_sparks
Posts: 2,660 PRO
Hi folks.
This PCB tool looks great (not used it yet but will soon), but just had to post this:-
We need more of this, bravo folks
3
Jake Rosenfeld - Modeling Team1 -
saw it late now but really cool!
it definitely helps in cases like this one: https://forum.onshape.com/discussion/3835/handling-large-stp-files
the Arduino example was a STEP file but it works for every crowd of bodies?
on the PS Technical Example it is visible that the Simplify PCB option removes the embossed letters as well as two thin cylinders representing a via or track (I guess). What is the limit height below entities are cutted away?
thanks in advance0 -
@mischl
If you see the documentation here:
https://cad.onshape.com/documents/9a9b81d17d4b69e58ad9b0b0/v/c253688ad8add5efd222a709/e/3152191074466a8b45231663
The "Simplify PCB" option will slice off all protrusions (no matter what the height) off of the top and bottom of the selected "PCB top face" and "PCB bottom face". The selected "Components" (parts which are unattached to the original board) are not affected by this option and will not be sliced away at all. These components can be simplified into boxes using the "Simplify components" option.
The origin of the parts is not important to the feature. Internally, all geometry is represented the same in Onshape after import. The feature will only work on solids, though. Surfaces are not allowed.Jake Rosenfeld - Modeling Team0 -
thank you for the explanation.
I red the documentation but have not considered the difference between protrusions and components, which have an additional face against the board...0 -
Is it possible to use this with assemblies? @Jake_Rosenfeld
I have existing imported pcb assemblies where the accompanying part studio is all the parts stacked together at the origin. Doing it there would not help much.
Thanks,
Mark1 -
Try using import into a single part studio when you import the file1
Or an in context edit of the assembly, followed by a transform copy in place of all the parts, then run the FS on that.Business Systems and Configuration Controller
HWM-Water Ltd2 -
For a collection of parts as large as a PCB normally is we would not recommend this option. Incontext is likely the best option.mbartlett21 said:Try using import into a single part studio when you import the fileTim Rice | User Experience | Support
Onshape, Inc.1
