How do I get my flange to resolve?
tim_ashbytim_ashby Member Posts: 3 ✭✭
edited January 2019 in Community Support
I'd like this flange on both sides of the model. Model file in question is Inserter.
Below are a few attempts at getting this to work - the problem seems to occur when the first flange is created on the other side.
https://cad.onshape.com/documents/894047f178a69979e5d421a2/v/f4d1c2d1fa6b612ca9d63dc5/e/67892f6a35401b87f1a308ab
Here, I had both initial flanges created in the same feature, which seemed to be a problem, but separating these out allowed some progression.
https://cad.onshape.com/documents/894047f178a69979e5d421a2/v/b7ad28d36e285b076ecf3897/e/67892f6a35401b87f1a308ab
https://cad.onshape.com/documents/894047f178a69979e5d421a2/v/1f5dfaf437e7ff45a3b9afab/e/67892f6a35401b87f1a308ab
These two files display basically the same problem - if the first flange on the other (left hand) side is below 20mm or so in length, Flange 16 just doesn't work.
https://cad.onshape.com/documents/894047f178a69979e5d421a2/w/bea36926bc95c216d9bf6d73/e/67892f6a35401b87f1a308ab
I had hopes of working around the problem, but it seems that if there is a flange on the left with a similar depth to the flange on the right, Flange 16 (in red) starts complaining about boolean failures.
Any suggestions as to why, please?
