Is this possible?
I found this image on the net.  I only know it was a moch-up from a design student.  I would like to bring this into reality.  I’m a photographer by trade, but a motorcycle enthusiast at heart.
is it possible to create a model using a photograph?  I have a good friend who owns a metal fabrication business with CNC tube/pipe benders and a CNC burn table.
    todd_sharkeytodd_sharkey Member Posts: 7
    Thank you Owen!  I get the sinking feeling that this might be over my head.
    Thank you Mr. Rice, I appreciate your suggestion.
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    If you have many photographs, you can use photogrammetry software to turn that into a mesh, which you can then use as reference in Onshape
    https://all3dp.com/1/best-photogrammetry-software/
    Thank you Mr. Bartlett.  I was only able to locate the photo posted, but I’ll keep your suggestion for future reference.
