Note Box Alignment on Drawings
S_RegulaS_Regula Member Posts: 95 PRO
Is there an easy way to align 2 or more Note Boxes (either horizontally or vertically) on a drawing?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,088 PRO
    edited November 2018
    Draw a line then you can snap the blue grip to the line (or edge of a part)
    this will move the text when the line moves.
    you can then delete the line when you're done.
    this works with balloons too
  • S_RegulaS_Regula Member Posts: 95 PRO
    @john_mcclary Does this work for vertical alignment as well?
    yes, any angle automatically
    @john_mcclary I'm trying to align two boxes vertically, so their left hand edges are aligned. When I drag the beige filled square to the vertical line as you suggest, it changes the size of the box. I want to maintain the box width, and "move" the entire box. Am I doing something wrong?
    oh, you want the text horizontal, but vertically aligned.
    hmm.. after playing with it for a bit, I can't find a way.
    Time to write up an improvement request :)
  • patrick_farleypatrick_farley Member Posts: 37 ✭✭
    You can align them manually, but there is no self align method that i know
    for moving the complete box just click in the middle of the text box, not on the beige fill square.
    By Clicking in the middle of the text Box and dragging it
    Sorry i just read the post again, and you probably did not need my advice on how to move text box.
    my bad
