Boolean Union
famadorian
Member Posts: 390 ✭✭✭
I don't understand why union doesn't work here to bring all these parts together?;)
https://cad.onshape.com/documents/d6022aa6ddb14022f3bdc386/v/512b3e1860a90572e15ac4fd/e/cd432193c4283b12a46ecbe8
OptionsPrachi Member, OS Professional Posts: 262 ✭✭✭Try changing extrude 5 from a surface to a solid.
Pretty sure Boolean does not apply to surfaces since there is no volume to add or subtract.2
Still, it doesn't work;)
I've rechecked all extrudes and they're all solids now:
https://cad.onshape.com/documents/d6022aa6ddb14022f3bdc386/v/6c97b54831dd4a0ef5090ca9/e/cd432193c4283b12a46ecbe8
I created a new Boolean and now it's all AOK;) Thanks
Shouldn't I be able to model it as a single object from the start, instead of merging them together at the end?
It's the extrude option that creates so many separate objects.
https://cad.onshape.com/documents/ba18a2fc12aee47138e1a96b/w/b97174d7e1757224dd5644b2/e/09f7d49698089039fd2204e4
I don't think assembly of the hangers is something I should do, cause they are welded together.
I do agree that boolean to bring it together is wrong, so I'll try to "add" when extruding and making sure they they intersect, and that I first model the intersecting geometry;)
https://cad.onshape.com/documents/d6022aa6ddb14022f3bdc386/w/a0b298083f9648005a11ca89/e/08385b13afc990f3ca782804
But with Onshape it's so easy to pull whole cabinet from single sketch and select between 'New' and 'Add' that it just makes no sense to create those dumb solids anymore. From part studio to assembly takes no more than 10 seconds to add whole ps, select all, add group mate - finished and ready for manufacturing drawings with full part list.
