Is there a way to store a dimension in a variable for use elsewhere?
chris_hockaday
Member Posts: 3 ✭
I know it is possible to define a variable and use it in dimensions, but I need to do it the other way around.
I have a length that is the result of various other constraints, and I want to use this to calculate the angle of a "flattened" cone, so that the length of the arc is equal to the circumference of a circle with diameter equal to this particular length.
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭you can use Measure distance FS with perimeter option to set the length of an edge to the variable
https://cad.onshape.com/documents/77baa8153589a7fc5f289829/w/cffd0f2a7077380d5378a885/e/d3174bf5315e6aafcb889367
2
Maybe I or @konstantin_shiriazdanov can help. What are you trying to use the feature to measure? Any specific questions?
