Need your advise for a piece with multiple curve
Banpie45Banpie45 Member Posts: 2
Hi,
I'm still trying to learn how to use the Onshape tools through the tutorial video. However I'm totally blocking on something that may seem easy for you (check the plan and picture i add)…
I'm using the same procedure as a sunglass modeling tutorial found on onshape using the tool "sweep + intersect" however I get not at all what I expect ..
So I may say that I use the wrong procedure and that I should use the "projected curve" or that I am totally wrong from the beginning.
Can you advise me on the most adapting procedure that I should use or redirect me on good tutorial because I am looking to learn and I am still discovering..
please excuse me for mistakes.
,Thank you
Pierre
