Booleans with Sweep Parts
philip_jarrettphilip_jarrett Member Posts: 2
Hello!
I am struggling with a project in which I have a complex, sweeped shape that was extruded along a splined path from a splined profile. The issue is that I am unable to perform any boolean operations on this part. For example, when attempting to subtract a cylinder from the sweeped part for a bolt, Onshape is unable to solve. However, when I attempted to create an example scenario for this post, I was able to successfully subtract a cylinder from a spline profile that was sweeped along a non-spline half-circle. Any ideas what might be going on?
Thanks,
Philip
    Hi and welcome.  It's always easier to help if you supply a link to your file.
    Details here on adice on asking for help, erm, if that helps:-
    Cheers, Owen S.
  • philip_jarrettphilip_jarrett Member Posts: 2
    edited March 2019
    Owen_Sparks,
    I wanted to share but I'm technically fiddling with a teacher's CAD part and don't know if I have their permission to share publicly. However, I believe I found at least a clue as to what was going on.
    I had a spline profile sweeping along a spline path. I applied a variable fillet to an edge of the resultant part. The slot I was attempting to subtract from the principal part was passing through the variably filleted area. When I suppressed fillets, Onshape was able to solve the boolean. Then, I was able to apply a new fillet. I wonder if the variable fillet presents a challenge for this scenario.
    Thanks,
    Philip
    @philip_jarrett
    It's likely that your subtraction was creating some kind on non-manifold geometry.  Here is an example:
    This sort of subtraction created an infinitely-thin portion of geometry on the part, as well as an infinitely-small connection on the top and bottom faces.  This type of non-manifold geometry cannot be constructed in Onshape.
