Hide Other Instances
famadorian
famadorian Member Posts: 390 ✭✭✭
After I've hit "hide other instances", is there a way to "unhide what I just hidden"?
I see there is a "show all", but this function shows all, even though I've spent time hiding stuff, so now I have to hide certain parts all again;)
  • famadorian
    You can also click on parts and select isolate, which will make everything transparent. Then you just close the dialogue box, or adjust the slider to unhide parts next to/connected to your selected part.
    Hehe, this is exactly what I mean;)
    Thanks;)
  • philip_thomas
    philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381 image
    @famadorian - You can;
    • 'Undo' the last hide
    • RMB/show all (everything including parts, sketches, planes, mate connectors)
    • RMB/show all instances (all parts/surfaces)
    • In an assembly you can create display states that store the hide/show state for later use in drawings
    I hope this helps :)
    Philip Thomas - Onshape
  • lana
    lana Onshape Employees Posts: 782 image
  • famadorian
    Well, I usually do something after I've "hide other instances", so I can't use "undo" here
  • famadorian
    "show all" and "show all instances" are not an option since they show too much and doesn't care about what I've hidden before I clicked the "hide other instances" function
  • famadorian
    that leaves display states; it seems I need to create a new display state every time before I hit "hide other instances" to be able to get back to the view I was at before I hit that function.
    Ok, I'll try.
  • philip_thomas
    @Famadorian - just out of curiosity, what CAD system are you coming from that has this?
  • owen_sparks
    owen_sparks Member, Developers Posts: 2,660 PRO
    Nope, and it's infuriating.  I believe there is an IR for such a thing though.  Nor can one configure visibility.  You could configure a delete parts to hide stuff though ;)
  • famadorian
    BRLCAD;)
  • famadorian
    Thanks;)
