Hide Other Instances
famadorian
Member Posts: 390 ✭✭✭
After I've hit "hide other instances", is there a way to "unhide what I just hidden"?
I see there is a "show all", but this function shows all, even though I've spent time hiding stuff, so now I have to hide certain parts all again;)
You can also click on parts and select isolate, which will make everything transparent. Then you just close the dialogue box, or adjust the slider to unhide parts next to/connected to your selected part.
6 -
Hehe, this is exactly what I mean;)john_mcclary said:You can also click on parts and select isolate, which will make everything transparent. Then you just close the dialogue box, or adjust the slider to unhide parts next to/connected to your selected part.
Thanks;)0
@famadorian - You can;
- 'Undo' the last hide
- RMB/show all (everything including parts, sketches, planes, mate connectors)
- RMB/show all instances (all parts/surfaces)
- In an assembly you can create display states that store the hide/show state for later use in drawings
Philip Thomas - Onshape1 -
Well, I usually do something after I've "hide other instances", so I can't use "undo" here0
"show all" and "show all instances" are not an option since they show too much and doesn't care about what I've hidden before I clicked the "hide other instances" function0
that leaves display states; it seems I need to create a new display state every time before I hit "hide other instances" to be able to get back to the view I was at before I hit that function.
Ok, I'll try.0 -
Philip Thomas - Onshape0
Nope, and it's infuriating. I believe there is an IR for such a thing though. Nor can one configure visibility. You could configure a delete parts to hide stuff though
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
BRLCAD;)philip_thomas said:0 -
6 -
Thanks;)0
