Perform a move face on sheet metal
Raphael_MassicotteRaphael_Massicotte Member Posts: 8 PRO
Hi,
I'm trying to perform a move face on sheet metal (more precisely an offset). When I do it manually, there's no problem but i've tried opMoveFace, moveFace and opOffsetFace and all of those throw an error that active sheet metal are not allowed.
Before i go looking in the std doc to find out how Onshape does it, does anybody know how I can do it easily?
Thanks
    @Raphael_Massicotte
    Operations generally do not work on sheet metal, so opOffsetFace and opMoveFace would not really be expected to work.  The implementation of our sheet metal features lies at the feature level itself, so moveFace should work for you.  Can you add a screenshot of what you are seeing?
    edited May 2019
    @Jake_Rosenfeld
    Can you give me an example to offset a face using moveFace? I'm getting
    Precondition failed (definition.moveFaceType is MoveFaceType) but I can't find how to define the moveFaceType correctly. I'm probably missing something stupid.
    Thanks
    I think I got it to work I was indeed missing something stupid
    Always helpful to say what you worked out so if someone else makes the same mistake they don't search the forum, find the perfect thread, get to the bottom and think, "oh good, I'm glad the original poster worked out what to do..." o:)
    Cheers, Owen S.
    Basically when moving from opOffsetFace to moveFace, i needed to add the definition "moveFaceType": MoveFaceType.OFFSET . I didn't write it correctly at first hence why it wasn't working.
    Thank you :+1:
    Cheers, Owen S.
