Perform a move face on sheet metal
Raphael_Massicotte
Member Posts: 8 PRO
Hi,
I'm trying to perform a move face on sheet metal (more precisely an offset). When I do it manually, there's no problem but i've tried opMoveFace, moveFace and opOffsetFace and all of those throw an error that active sheet metal are not allowed.
Before i go looking in the std doc to find out how Onshape does it, does anybody know how I can do it easily?
Thanks
Thanks
Operations generally do not work on sheet metal, so opOffsetFace and opMoveFace would not really be expected to work. The implementation of our sheet metal features lies at the feature level itself, so moveFace should work for you. Can you add a screenshot of what you are seeing?
Can you give me an example to offset a face using moveFace? I'm getting
Thanks
Cheers, Owen S.
