Documentation
scott_caskey
Member Posts: 55 PRO
Where to I find documentation on the profile generator feature script? I'm designing a wing and don't understand what "two points" I need to select for the airfoil selected.
Generally a custom feature's documentation lives in the document the FeatureScript is written in. You can right-click the feature in your toolbar and "open linked document" to see that document at the version you're using.
If you don't see documentation there, can you post a link to it here, so we can tell which FeatureScript you're talking about?0 -
Excellent. Thanks!0
Here is a link to the PDF you need
https://cad.onshape.com/documents/4bf18c75321ea2c8c2ea770d/w/978aece63f59e09169309756/e/b319e7a87bba701e3e02a0fa
