Off line Cache - Fusion 360 Case
yong_kim
yong_kim Member Posts: 30 ✭✭
Hello everyone.
The video at the following URL is FUSION360 description,
Especially, 1) it will switch to off line mode after login
2) Off line mode explains how to use Cache to work and save.
3) The off-line mode is required because Korea's official test regulations do not allow Internet connection.
If this technique is also supported by Onshape, Onshape can be selected as an exam tool in the certification exam.
Is not the future of Onshape quite relevant to the investment of education on youth?
Here is a sample 3D Printer Certificate test.
