Onshape mobile featres
bryan_lagrange
Member, User Group Leader Posts: 800 ✭✭✭✭✭
Is there a document or a web page that list all of the design features you can perform on Onshape mobile? Are there plans for sheet metal features becoming available on Onshape mobile? Do Android and IOS have the same amount of features or does one have more than the other?
Thank you
Thank you
@bryan_lagrange
Document or webpage on features?
Below are the main differences between the desktop version and the iPhone app
REGARDING THE IPHONE APP ——
No Drafting
No creating Configurations. But, you can change or alter Configurations created on the desktop
No Feature Studios (emphasis on STUDIOS) i.e. no script writing
There is sheetmetal. But sheetmetal does not have the real-time unfolded window
Now with the above said ———
I really don’t see any big difference between desktop and iPhone when you’re modeling (in Part Studios)
Assembly doesn’t seem that different either, but I’m not someone who has done extensive Assembly work, so others could better speak to this
Where the iPhone app has the desktop beat in a very big way is convenience. My opinion. By the way — I’m sitting semi-reclined in my La-Z-Boy right now with my feet up watching TV and using Onshape on my iPhone
After looking through the help as @MBartlett21 pointed out, I added that you can CHANGE configurations
On the help page for each specific feature, it says which platforms it is on at the top
Twitter: @BryanLAGdesign
I probably should’ve gave you more detail on the sheet-metal tools earlier in the previous post, so for what it’s worth, here are the exact sheet-metal tools / FeatureScripts that I have
for now the work around is to open a mobile browser, add your feature then go back to the app and edit.
I'm not sure if there is an IR for android sheet-metal, but you should create one if you find yourself stuck in the mobile environment often
Drafting and configurations would be really useful on mobile.
I find a lot of minor issues, such as the colour hints for axes seem to be missing in tools like transform and assembly mate offsets, no variable autocomplete (or variable refactoring!), and batch changing of appearances.
Most are trivial but would be really beneficial for a mobile app, especially without a keyboard attached.
I'd also like to see a full equation editor with macros and intellisense and refactoring, along with project or global variables that can be accessed by part studios, assemblies, drawings and featurescripts.
