Invisible section view face
vladimir_synek
Member Posts: 2 ✭✭
Onshape Free version, some time ago I played with settings and from that time my Cross section face is invisble.
When I make sketch with regtangle, than extrude it in solid object,
next "Turn section view on" by some plane I get the section view without visible face.
It seems it is in OnShape settings because I get the same layout with old projects which worked....
Any help, please ?
Any help, please ?
Hi Vladimir, Are you on Chrome? If so, this a bug with Chrome, here is more information : https://forum.onshape.com/discussion/11912/section-view5
Hi Paul, yes indeed - I have W7 64bit with Chrome as main browser. Further I tried onShape on Opera, but I have the same problem there. Based on your link I installed the Firefox and the section view in it is OK (=solid with cross section pattern)...
So, I have Chrome v.76 and there are hopes in the linked discussion v.77 will solve this issue.
Nevermind thank you for good information.
Cheers0
