Offsetting complex, closed shapes made up of arcs.
stephen_dewing
Member Posts: 23 ✭
In sketch mode, I am trying to offset a closed, complex shape with lots of arcs but keep getting any one of the following messages "Offset could not be created at this distance" or "Sketch can not be solved" or "Can only offset a single chain at once."
No matter what closed shape I make with arcs, how big or small, it will not offset either inwards or outwards.
Can anyone help me please? Is this a problem with the program or just my understanding? Desperate!
owen_sparks Member, Developers Posts: 2,660 PROOK, lets hit the issues one at a time.Is this the type of fillet you're after?If so you need to join the individual parts together before the fillet. (Using the boolean tool.)Owen S.
HWM-Water Ltd5 -
owen_sparks Member, Developers Posts: 2,660 PRONot quite. In your last example you extruded a line which will give a surface. We want to extrude "sketch regions" to make a solid part.To boolean two solid parts there is no need to select faces, we just select the parts we want to join together.To end up with a .45mm thick wall we have a few options. We can either extrude it solid and then use the shell feature and tell that feature we want a .45mm wall, or just start with something .45mm and extrude it up.Cheers, Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
Please post a link to your document as detailed here: https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
It is likely that either the sketch is not closed (area is not shaded) or the arcs are too small. Select the offset tool and click/drag one of the entities to get a smaller offset (your arcs may be smaller than the default 5mm).
In this link, I haven't taken out the bottom and the wall is way to high but it will suffice for this illustration. You can see what I mean I think. It added a fillet on top of the rim but it is convex not concave. Thank you in anticipation.
I'm still struugling. Wasn't able to colour the parts so just done another part without the fillet. You will now see the top of the rim/handle of the cutter is flat. I am trying to put a concave fillet on the top surface of the rim rising up the surface of the cutter blade. This is to strengthen where the cutter wall intersects the rim. The other problem I have now is I am struggling to protrude the whole of the cutter wall. At present, as you can see, I have part of the rime protruding into the centre of the cutter. It is meant to be right on the edge. Hope you understand.
https://cad.onshape.com/documents/7911a70ce5cdf73827c8d990/w/7ff3e5206ffd618ada34723f/e/22cb13049b00771b754ffceb
I also wondered if Onshape allows you to make a small program, whereby I could insert any shape with all the dimensions and it automatically extrudes, adds rim and fillets etc? From what I have read, it seemed that you might be able to, but not 100% sure. If so I presume there would be tutorials on how to do it. Thanks again so much for your help.
https://learn.onshape.com/learn/course/fundamentals-part-design-using-part-studios/creating-basic-part-features/fillet-and-chamfer
BTW Boolean is one type of feature and Fillet is another
