Assign weight to a mocked up part
jon_smirl
Member Posts: 15 ✭✭✭✭
I'd like to get an estimate for the center of gravity of my design. The design includes multiple mock ups of purchased parts (like motor, speaker, etc). I'd like to enter a weight for the part. It is good enough for my purposes to assume uniform density of the part. I see we can pick materials for a part, but I see no way to simply enter a weight.
It is also too hard to search for a density in the material list that is close since the densities are in alphabetical order, not in order of density.
It would be nice to be able to specify density's / make custom materials and add a known weight to be uniform across the part independent of density.
https://cad.onshape.com/help/Content/material_library.htm
Very handy when working with imported files that have only surfaces or no material defined.
You can set weight to catalog value as is needed.
