Release Configuration Option Inside of Assemblies
Michael_Coffee
Member Posts: 90 ✭✭✭
Going forward at our company, we only want to use released models. Versions, of
course, will be used for development, but releases will be the control
for the models. Part configurations are fairly straight forward in their
release management to where you pick your options from the tables
you've created and release it. It only works well when it comes to
parts, however. The moment we try to use assembly configurations with
release management, the entire structure falls apart. Let's say you have
a rectangular support bracket that is bolted together at the corners
and its size varies with each location its used in. With versions, works
great. If we release the individual pieces and try to use them, it no
longer becomes configurable. That translates to us needing to insert
each release to their respective locations and create mates for each
piece. The mates won't allow a suppressed model to be used, or otherwise
that might be a workaround, but only slightly.
What
we would need is the ability to make releases a configuration option,
allowing us to switch between releases that are inside of the model.
Otherwise, releasing configured assemblies with released models does not
work. The amount of time needed to insert and mate together each piece
makes it unusable in the time that it is needed.
Thank you for your time =D
Is there a separate post somewhere I can vote on?
