I want to connect the pipes in this heat exchanger.
mario_darceuil
mario_darceuil Member Posts: 113 ✭✭
I want the ends on the left to be connect with a funnel at the top and the ends on the right to be connected with a drain to the bottom. I attempted to draw lines then sweep them to make pipes but I couldn't get the lines oriented because I don't understand how the faces work. Please help.
