how can I change the default offset value in sketch?
C_D_R
C_D_R Member Posts: 5 PRO
My offset always defaults to 5(mm) which is often too large for the features I am working with and will cause a failure before I can choose an appropriate value.
  • C_D_R
    Drag the arrow.  Gotcha!  Thanks.
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,103 image
    If you click the icon first then drag the geometry you can drag to values less than 5mm.
  • steve_shubin
    steve_shubin Member Posts: 1,118 ✭✭✭✭
    @C_D_R
    And you can select a number of lines to offset using one numeric input
