how can I change the default offset value in sketch?
C_D_R
Posts: 5 PRO
My offset always defaults to 5(mm) which is often too large for the features I am working with and will cause a failure before I can choose an appropriate value.
Click and drag to create values other than 5mmSenior Director, Technical Services, EMEA6
Drag the arrow. Gotcha! Thanks.0
If you click the icon first then drag the geometry you can drag to values less than 5mm.Senior Director, Technical Services, EMEA0
