Calculator inside Onshape
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 794 ✭✭✭✭✭
It would be nice to have a calculator feature inside the design work space of Onshape.
Bryan Lagrange
Twitter: @BryanLAGdesign
    Piotr_Smektała_VBPiotr_Smektała_VB Member Posts: 26 ✭✭
    @bryan_lagrange, Are you thinking about OS internal feature?
    Now, you may have a calculator open in background and use keyboard to switch between OS and Calc.
    I think, something like a keyboard shortcut to open external (configurable) app could do the trick faster.
    Is it somehow important that it should be evoked by mouse?
    I am just looking for something within the software so there is no back and forth.
    Bryan Lagrange
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,898 PRO
    I'd rather just type the equation in the dimension and have it give the result. Like SW does so well...
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    @bryan_lagrange
    With the windows calculater there is an 'always on top' mode that is activated by the popout button to the right of 'Standard'
    ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,175
    Would it solve the problem to have a shortcut key (like CTRL+Enter) that replaces an expression with the result of evaluating it in feature parameters and dimensions?  Implementing a calculator inside Onhsape is a bit out-of-scope.
    I would accept ctrl+enter
    Like that idea :+1:
