Auto Populate Drawing Name from Part Name, Number, and Revision
marshall_wentworth
Member Posts: 10 PRO
Does anyone know how to populate the drawing name (what's found on the tab when the drawing is created) from other part meta data, such as the part name, part number, or revision? For instance, if I have a part, and in its properties panel in the part studio, I give it the description of "Bracket", and I give it part number 10, revision A, when I right click and say new drawing from part, can I get Onshape to create me a drawing titled Bracket-10-A, or some combination of those values? I'm tired of exporting drawings and having to delete the "drawing 1" suffix, or having my drawing name not auto update with my revision number, which we add after exporting the drawing.
Thanks!
Thanks!
Optionsraj_Onshape Onshape Employees Posts: 106What is your expectation if for part number 10 + rev A you create a drawing. Now you update the part number 10 to create rev B Would you create a new drawing or update an existing one ?
Are you simply looking for the a suitable default during export ?
Something configurable like $PARTNUMBER+$REVISION+DESCRIPTION
There is also the case that you can have multiple sheets on a drawing which have views of multiple parts.
3 -
OptionsDon_Van_Zile Member Posts: 195 PROraj_Onshape said:Something configurable like $PARTNUMBER+$REVISION+DESCRIPTION
That would definitely make a good starting point too.6
According to me, this is a feather that must be in from the beginning.
I was using Inventer in 2006 and used this feather every day.
