I want to bend a flat part for a assembly mounting illustration
jan_gaare
Member Posts: 7 PRO
Hi there, maybe someone can easily tell me how to bend this part, f.example. on a curved surface.
The yellow part, toward the viewer.
https://cad.onshape.com/documents?nodeId=3&resourceType=filter&q=type:document%20name:MBartlett
If you upload the file others with some experience using those may help.
I think this is the custom feature Nik mentions: https://cad.onshape.com/documents/a39db7615a2a945ffb7076c3/w/52c7bee2296b4e4eb30c2b9d/e/279e25dcd74a1b2eafeba514
You can click the "+ Custom features" button in that document to add it to your toolbar
@Jake_Rosenfeld
There is also my Sheet metal fold feature:
https://cad.onshape.com/documents/9f116620b0f6d04445f57293
