Extrude did not regenerate properly
jailene_castillo556
Member Posts: 4 EDU
I'm trying to extrude each individual piece of the snowflake and most of them extruded correctly. However a few pieces won't extrude properly and show up in orange with a bright orange side. All the pieces are closed.
https://cad.onshape.com/documents/46765e94b47fb6128c4d847f/w/a6e2fd7850fb6c8eb73f955c/e/701ca62a88079bee41b165a2
Sorry, that link is broken.Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
Sorry, You will need to make your document public with copy permissions for us to check it. See the post here for instructions.
www.accuratepattern.com0 -
Sorry that's read only link so we can't do much to help with that.:-
Please have a look at this post:-Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
@owen_sparks , as you can see up the top, it is still a public document. You can copy it once you log inowen_sparks said:Sorry that's read only link so we can't do much to help with that.:-
