How to place the secondary dimension to be after the primary one ?
Alex_Huang006Alex_Huang006 Member Posts: 12 PRO
In the drawing environment, I made the dual dimensions. But How can I place the secondary dimension to be after the primary one ?
  • mlaflecheCADmlaflecheCAD Member, Onshape Employees, Developers Posts: 197 image
    You can set the dimension properties using the wrench icon on the right side of the screen to set which unit is on top of the other.
    Regards,
    Mike LaFleche   @mlaflecheCAD
  • Alex_Huang006Alex_Huang006 Member Posts: 12 PRO
    No. I double checked the dimension properties. That setting will change all dimensions. What I want is to change the one I expect. And I want to put the secondary unit to be after the primary dimension rather than "bottom" or "top.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Again, currently not possible. These are all on our radar, but cannot promise timescales.
