Intersection dimensions lines and radius selection drawing
Barry_van_Wijk
Member Posts: 46 PRO
Hi,
1- How do i create the blue dimension line?
2- I cannot select with "dimensions" or "radial dimension" the radius in section view and detail section view (green).
In normal projected views I can select the radius
can you select the vertical edge an the horizontal edge with virtual sharp?0
sorry for the late reply. but it was helpfull!0
