Need help on using Recursion(function calls itself)
Hi,
Anybody used recursion function in FS. I am getting id issues while calling the function itself. Any help would be great. Thanks.
  • konstantin_shiriazdanov
    edited July 2020
    The problem with id can be solved by passing to function an iterator variable of box type, generating the id with it, and incrementing.
  • Kirankumar_Thimmegowda
    Kirankumar_Thimmegowda Member Posts: 28 PRO
    edited July 2020
    Thanks for the answer. I tried something like this at call "getArc(id + i*0.01, context,pF,SecAng[18-i],aEvol[i])" & at function definition "export function getArc(id, context,pF, Ang, ttRefArea) returns map". It worked.
