Need help on using Recursion(function calls itself)
Kirankumar_Thimmegowda
Member Posts: 28 PRO
Hi,
Anybody used recursion function in FS. I am getting id issues while calling the function itself. Any help would be great. Thanks.
The problem with id can be solved by passing to function an iterator variable of box type, generating the id with it, and incrementing.
Thanks for the answer. I tried something like this at call "getArc(id + i*0.01, context,pF,SecAng[18-i],aEvol[i])" & at function definition "export function getArc(id, context,pF, Ang, ttRefArea) returns map". It worked.0
