Need help on using Recursion(function calls itself)
Hi,
Anybody used recursion function in FS. I am getting id issues while calling the function itself. Any help would be great. Thanks.
    edited July 2020
    The problem with id can be solved by passing to function an iterator variable of box type, generating the id with it, and incrementing.
  • Kirankumar_ThimmegowdaKirankumar_Thimmegowda Member Posts: 28 PRO
    edited July 2020
    Thanks for the answer. I tried something like this at call "getArc(id + i*0.01, context,pF,SecAng[18-i],aEvol[i])" & at function definition "export function getArc(id, context,pF, Ang, ttRefArea) returns map". It worked.
