Drawing View Labels for standard views?
David_BoneDavid_Bone Member Posts: 47 ✭✭✭
I read an old update that stated "Optional view label and/or view scale label notes for all views".
But I don't see the View Label option for standard views (only the Scale Label option).  The View Label option is available for other derived views (section, detail, etc.).
Am I missing something?
I rely on this for many views especially when the views are very symmetrical.
    bobminerbobminer Moderator, Onshape Employees, Developers Posts: 50
    Hi David,
    Thanks for your question.
    Detail views and section views have a view label and you may add a prefix and suffix to the view label.  But other types of views do not currently have a view label.
    As a workaround for now, you could create a note under the view.  The note may contain your view label text.
    Thanks -Bob
    Bob Miner - Software Engineer / Dev Leader - Drawings - Onshape, Inc.
    Thanks Bob, That is what I have done, but you have to move the notes if/when you move the view.
    I assume there is no option yet for linking a note (without an arrow to a view feature) to a view?
    -David
    andrew_kleinertandrew_kleinert Member Posts: 47 PRO
    +1 for being able to add view label for standard views (non-section / non-detail)
    arjan_bokarjan_bok Member Posts: 13 PRO
    +1 view labels for standard views is a must have ;)
    david_gaitsdavid_gaits Member Posts: 1
    +1 view labels. Would be awesome.
    shaun_scottshaun_scott Member Posts: 2 EDU
    +1 view labels for standard views and add the option to the sheet properties to turn on labels for all views.
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    I have created an Improvement request for this:
    https://forum.onshape.com/discussion/13931/view-labels-in-drawings/p1
    Please vote up to let Onshape know that we need this feature.
