Improvements to Onshape - September 15th, 2020
Roy_Mutalik
Member, Onshape Employees Posts: 41
We've already reached the middle of September! I hope you all continue to stay safe and well.
Let's take a look at some of the improvements to Onshape in this release.
Mate Connectors will also be suppressed automatically if their owner part is suppressed.
In order to set up this type of field, you'll need to add the properties you create to a Category which has "Versions" and/or "Workspaces" set as the scope.
For more information on Categories, make sure to visit the help documentation!
Onshape's underlying kernel, Parasolid, has been updated to V33. This provides you with the latest advancements in geometry, and allows you to export the latest format.
Data created in and owned by the Enterprise cannot be made public even if a user has share permissions, so your data is still always secure. Enabling the public filter in an Enterprise simply makes it easier for user to copy data into the Enterprise for use, such as public custom features, vendor or supplier models, or even training materials.
CAD IMPROVEMENTS
MATE DETAILS TOOLTIP
A new mate details tooltip is available when mousing-over a mate or mate connector feature in the features list.SECTION VIEW OF A SECTION VIEW
You may now create a new section view, defined from an existing section view in a drawing.AUTOMATICALLY SUPPRESS MATES
A mate will now automatically be suppressed if a part used to define that mate is suppressed.Mate Connectors will also be suppressed automatically if their owner part is suppressed.
PROPERTIES FOR VERSIONS AND WORKSPACES
You may now create custom properties for an entire version or workspace in a document. This is useful for capturing metadata that might apply to all of the tabs, such as a project number or job type.
FOLLOW MODE SHOWS DIALOGS
When following another Onshape user using 'follow mode' you will now see the dialogs for any sketches or features they edit within a Part Studio.3D FIT SPLINE FOR MODEL AND SKETCH EDGES
A new option has been introduced in the 3D Fit Spline feature allowing for the selection of model and sketch edges. It converts these multiple edges into a single curve.PARASOLID UPDATE
ENTERPRISE IMPROVEMENTS
GLOBAL PERMISSION FOR CREATE DOCUMENTS AND FOLDERS IN MY ONSHAPE
A new Global Permission has been added, allowing administrators to control which users of an Enterprise can create documents at the My Onshape page. If this permission is not allowed, a user will only be able to create documents or folders within folders to which they have the appropriate permissions.BROWSE PUBLIC DOCUMENTS FROM AN ENTERPRISE
You can now easily browse through public documents, even when signed in to an Enterprise domain.
2
Awesome update!! Thanks!0
Lots of cool stuff as usual
Suggestion - in the same way that 'fixed' parts have an icon, it might be helpful if the mate icon had a variant that indicated whether limits were present in the mate. This would help identify why a mechanism would reach a state where it could no longer move and answer the question, 'is this because the mechanism bound or was a mate limit reached?'. It would also identify those mates that might control the extents of motion of a mechanism.
5 -
Automatically Suppress Mates -Thank you!!
Follow Mode Show Dialog
Global Permission
All useful thanks2 -
Whaaa? Suppressing a part.. suppresses the mate??
Great stuff as always, keep it up OS10 -
Automatically suppress mates?? YES PLEASE!Also, follow improvements is great! Will certainly use.0
mate suppression, show dialogues in follow mode, and the edges in the fit spline are it for me. nice!1
I really like the follow mode. Great job!1
The mates and dialogues are good.
What does this mean in the changelog: REST API: Add rollback bar to EvalFeatureScript endpoint0 -
Some handy improvements. "Auto" mate suppress, section on section and follow mode is really helpful.0
Great improvements, all very helpful
Automatic mate suppression will simplify a lot assembly configurations
Properties in Workspaces and versions are great, but we can't use it linked in a drawing note (like in the titleblock)
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
As of today, you can't tell the difference between an inactive mate and a hidden mate
Seeing how mates are normally hidden, it would be nice if the suppressed mate had a marker that shows it is inactive, without having to mouseover and read the tool tip.
I agree it shouldn't be crossed out like a normal suppress because it is nice knowing which were suppressed manually from a config.
I always hated having to mouseover in SW too when checking the status of a suppressed mate. Now is a good opportunity to do it better the SW again
Maybe you could have just plain text appended to the name rather than a symbol:
Fastened 3 (Inactive)
6 -
Hi MBartlett21,MBartlett21 said:The mates and dialogues are good.
When calling the evaluate FeatureScript endpoint (`/partstudios/d/:did/[wvm]/:wvm/e/:eid/featurescript`) it now accepts a query param to indicate where the rollback bar should be evaluated to, ex. `?rollbackBarIndex=0` will rollback the entire feature list.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com1 -
Mate Detail Tooltip is a great addition, but would be even nicer if it showed the name of components assigned to the mate. For a simple model as the cylinder, you can easily visualize them in the 3D model, but when having an intricate design, with lots of components bunched together, it quickly becomes harder to distinguish which components are mated together.
As @john_mcclary pointed, it would also be great to have a visual cue of which mates has been suppressed together with the suppression of a part or ass'y.
Altogether, these improvements are very welcomed.3 -
Great stuff OS team. The mate improvements will be a blessing for building configured assemblies.
Cheers!0 -
I'm still going to press for a better Instances Tree structure in assemblies. My scrolling finger is getting sore from having to scroll so much. Need to be able to have things in a Windows style tree which can open a group of objects folder with a (+) or close with a (-) or something. (See your pals in the Creo Dept.) Also, having the Mates in the Instances Tree is still an overwhelming use of valuable real estate. Can't we have a way to click on a part and open up a Mate Dialogue box for it instead?
2 -
If you long click on a mate in the graphics area it will Isolate just the two parts that are mated. Same result if you right click on the mate and select Isolate:HuguesLessardWRI said:Mate Detail Tooltip is a great addition, but would be even nicer if it showed the name of components assigned to the mate. For a simple model as the cylinder, you can easily visualize them in the 3D model, but when having an intricate design, with lots of components bunched together, it quickly becomes harder to distinguish which components are mated together.
Onshape, Inc.3 -
Oh, my bad, it does look like they are identifiable.
Hidden mates are light gray
Inactive mates are light gray + Italicized text + lower half of icon is lighter
all of that and I still barely noticed the first time
The ability to sketch on drawings would be handy. And, of course, displaying simplified external threads on drawings, or at least sketch them. Inserting a symmetry symbol (not the GD&T symmetrical symbol) would be nice, too.
I am colorblind and I find the difference too thin. A better visual indicator would be more than welcome. I offer to be the community colorblind representant for Onshape!john_mcclary said:Oh, my bad, it does look like they are identifiable.
But great improvements again!5 -
Thanks Tim, I haven't seen this one and it sure is a great tip, but how much clicks those it take to find that fastened 1 assembled Part A to Part B, rather than just hovering over the mate itself. Just saying that could be great if we could hover every mates and having part names listed at very first glance. Understanding how an assembly has been built would be much easier and less time consuming (same goes for debugging bad mates) especially when you run over a couple of those in a single assembly.TimRice said:
1 -
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común1 -
Section view of a section view!!
This is a fantastic update. Thank you Onshape team!
RENDERCAD
________________________________________________________________________1 -
Nice Update. I really like the auto suppress mates when part or assemblies are suppressed.
On the tip, firstly I'd like to be able to highlight areas when I mouse over but this may be done deliberately but what I really want to know is, if things are configured or not, this would make it much more helpful.
See here nothing tells me the 58in is configured on the tooltip
I have to open the edit dialogue
7 -
I was trying to make this work too. Having all the info for all the title blocks in my document just pull from one place would be super helpful.emagdalenaC2i said:Properties in Workspaces and versions are great, but we can't use it linked in a drawing note (like in the titleblock)
Each of those drop downs are scanning a different scope of properties. So you can have two properties on different levels with the same name and can clearly tell the difference1
How do I get the word SECTION to appear
automatically like in the video? After creating any section or detail view I have to open view properties and type it in. have I missed some setting somewhere?
@Ben_Tek_Pac
As far as I know, it always appears automatically.
Are you sure you are not doing a projected view or auxiliary view?0 -
I only get the A-A. Maybe it is depending on the language you selected in Onshape?0
No it is not a projected view or auxiliary view, as sebastian_glanzner say I only get A-A for sections and only get A with the scale underneath for detail views.john_mcclary said:@Ben_Tek_Pac
I found it, if you use ISO it doesn't have it. If you have ANSI it does. It should be on the ISO. really needs the option to have it or not have it.sebastian_glanzner said:I only get the A-A. Maybe it is depending on the language you selected in Onshape?4
https://youtu.be/TWEWEm-vGJw
