Issues getting opExtrude working with UP_TO_FACE
aaron_skidmore
Member Posts: 34 ✭✭
Hi there I have opExtrude working with BLIND as below - no issues
But when I try and do UP_TO_FACE, no matter what I try I cant seem to get it going, the debug line is showing the correct face. The warning is
debug(context, bottomface);
opExtrude(context, id + "extrude1", {
"entities" : regionToExtrude,
"direction" : zDirection,
"endBound" : BoundingType.BLIND,
"endDepth" : 5 * millimeter
@opExtrude: EXTRUDE_SELECT_TERMINATING_SURFACE, which indicated it want a surface not a face? |
var faces = qAdjacent(bottomedge, AdjacencyType.EDGE, EntityType.FACE);
var bottomface is Query = qLargest(faces);
"endBound" : BoundingType.UP_TO_FACE,
"endBoundEntityFace" : qNthElement(bottomface, 0)
It’s “endBoundEntity”Senior Director, Technical Services, EMEA0
Thanks Neil, that did it - where is this documented, I must be looking in wrong place (https://cad.onshape.com/FsDoc/library.html#module-extrude.fs)0
