Parts vs Surfaces - got a surface when I wanted a part
Kevin_Halverson
Member Posts: 3 PRO
NeilCooke Moderator, Onshape Employees Posts: 5,310Your sketch should be shaded to indicate an enclose profile which is required to make a solid. Or you selected the edges rather than the shaded area.Senior Director, Technical Services, EMEAI5
