Configuration Table problem
GHamsz
I’m a relative newbie, so consider that...
Any idea what’s going on here?
I’ve used a configuration table before without issue, but for some reason I can’t reference the variables in this table.
I also don’t get any hint as to what the problem is.
@GHamsz
It looks like you're using a mobile version of Onshape (iPad?). I don't think that variables are available on mobile (yet!).
@steve_shubin (who is a master on mobile) is that true?
I deleted that part studio, created a new one, and it’s working as expected now. There was something fishy with that part studio.0
variables work fine in the iOS mobile version. You can’t manage configuration tables, but if you create them in a browser, you can use the variables on the mobile version.
I may have found the root cause of my problem. I didn’t realize that when you rename a configuration variable, that the underlying #name isn’t changed.1 -
@steve_shubin
Can you see the issue with the original poster's question?0 -
@romeograham
I’m guessing you guys both posted at the same time
Evidently @GHamsz has it working good
1
