Configuration Table problem
I’m a relative newbie, so consider that...
Any idea what’s going on here?
I’ve used a configuration table before without issue, but for some reason I can’t reference the variables in this table.
I also don’t get any hint as to what the problem is.
  • @GHamsz
    It looks like you're using a mobile version of Onshape (iPad?). I don't think that variables are available on mobile (yet!).
    @steve_shubin (who is a master on mobile) is that true?
  • steve_shubin
    steve_shubin ✭✭✭✭
    Hi @romeograham
    You can indeed make variables using mobile
  • I deleted that part studio, created a new one, and it’s working as expected now. There was something fishy with that part studio.
  • variables work fine in the iOS mobile version. You can’t manage configuration tables, but if you create them in a browser, you can use the variables on the mobile version.
    I may have found the root cause of my problem. I didn’t realize that when you rename a configuration variable, that the underlying #name isn’t changed.
  • @steve_shubin
    Can you see the issue with the original poster's question?
  • steve_shubin
    steve_shubin ✭✭✭✭
    @romeograham
    I’m guessing you guys both posted at the same time
    Evidently @GHamsz has it working good
