Illustration of gear mate issue in recent question.
When I was using Solidworks, all I had to do was link two gears, and if either was turned by anything else it was mated to, the meshed gear would respond.  Does OnShape not have a similar aspect?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,052 PRO
    edited November 2020
    You will need to add a gear relation to each mate you want moving.
    It will make more sense the more you become familiar with the more generic mate connectors and relations of Onshape.
    Rather than the specific and niche mates of Solidworks.
    Then you can make things like this useing nothing but relationships
    https://www.youtube.com/watch?v=SMTeEhbCPzo
    @wesley_church - Another thing that's different from Solidworks, is that it's much easier to use a single mate between any two parts. This is one of the things that tripped me up a bit when I first started in Onshape, but I think its great now that I got the hang of it. I'm not sure if it will affect the way your gears move in the example above, but it might help with troubleshooting.
    In your example, you have two planer mates to constrain each gear to the shaft. If you don't want these gears to move at all on shaft, it would likely be easier (an probably faster for the model to re-build/animate) if you replaced those with a single fixed mate for each gear.
    When you're mating something, rather than building up constraints by adding together several coincident, planar, tangent, etc. mates between the parts, you can go the other way. Fixed is completely constrained (rotation and translation), but you can identify where you want motion and select the mate that allows that motion. So, if you just want rotation around one axis, but no translation in any direction, you can select a revolute mate. If you want to allow rotation and translation along a single axis, then you're looking for the cylindrical mate.
    I think this also helps with chasing down errors if anything occurs, as it's easier to find the single mate defining the relationship between two parts rather than having to figure out which one out of two or three may be causing the issue.
