how to specify circle with Radios dimension ?
asi_perach
asi_perach Member Posts: 3 PRO
how to specify circle with Radios dimension ?  :smile:
  • brian_brady
    brian_brady Member, Developers Posts: 505 EDU
    You need to Split the circle or Trim it to add a radius dimension. You also cannot put a diameter dimension on a circle that has been trimmed or an arc (yet ... crossing fingers it gets added).
  • fastwayjim
    fastwayjim Member, OS Professional, Mentor Posts: 220 PRO
    In a sketch, you can always type in the radius dimension and multiple by 2. Whenever the dimension is edited, the equation will always reference the original value of the radius, even though it solves as/shows the diameter.
    For example, when I use a 1/8" radius to make a 1/4" diameter circle:
  • T_Rathier
    T_Rathier Member Posts: 47 EDU
    In the dimension options box (where you set precision etc.) there is a toggle at the bottom to switch between radius and diameter as the dimension type.
  • w_s856
    w_s856 Member Posts: 63 ✭✭
    Could you please guide me to that options box? (new to oneshape, I am not yet very comfortable with what is where)
  • NeilCooke
    That is in Drawings only. For sketch only diameters for circles and radii for arcs.
